[gdal-dev] Ingres driver on Windows
Thu Jan 26 04:03:11 EST 2012
On 12-01-25 11:23 AM, Tyler Mitchell wrote:
> I've bundled together just the basics that I think are needed.
> http://db.tt/0LtX9YvL
Tyler,
Cool, that seemed to have what I needed.
> Linux variables seem to look for:
> INGRES_LIB -> ingres\lib
> INGRES_INC -> ingres\files
There was no build support on windows.  I've added it in trunk:
   http://trac.osgeo.org/gdal/changeset/23805
   http://trac.osgeo.org/gdal/changeset/23806
You can see in the nmake.opt an example of what needs to be set.  Note
there is no precise correspondence between windows builds and unix
builds with regard to variables needed.  So on windows they are
slightly different.
I was able to build and link, but I didn't try running since I don't
have a windows instance.
> They aren't officially distributed separately as a library package, so I might
> have missed
> something doing it ad-hoc.
> I'd be thrilled if you get a chance to peek at it. I'll be in IRC if you have
> thoughts to share or things I should try.
If you svn update from gdal trunk you should be able to build.  I'm also
interested in trying an OSGeo4W package for INGRES support but it is
getting a bit late tonight to push on that.
Best regards,
light and sound - activate the windows | http://home.gdal.org/warmerda
and watch the world go round - Rush    | Geospatial Software Developer
