[gdal-dev] Ingres driver on Windows
Tyler Mitchell Tyler.Mitchell at actian.com
Thu Jan 26 13:07:07 EST 2012
Awesome, I'm going to check it out today for sure!
Thanks a lot!
Tyler
On 2012-01-26, at 1:03 AM, Frank Warmerdam wrote:
> On 12-01-25 11:23 AM, Tyler Mitchell wrote:
>> I've bundled together just the basics that I think are needed.
>> http://db.tt/0LtX9YvL
> Tyler,
> Cool, that seemed to have what I needed.
>> Linux variables seem to look for:
>> INGRES_LIB -> ingres\lib
>> INGRES_INC -> ingres\files
> There was no build support on windows.  I've added it in trunk:
>  http://trac.osgeo.org/gdal/changeset/23805
>  http://trac.osgeo.org/gdal/changeset/23806
> You can see in the nmake.opt an example of what needs to be set.  Note
> there is no precise correspondence between windows builds and unix
> builds with regard to variables needed.  So on windows they are
> slightly different.
> I was able to build and link, but I didn't try running since I don't
> have a windows instance.
>> They aren't officially distributed separately as a library package, so I might
>> have missed
>> something doing it ad-hoc.
>> I'd be thrilled if you get a chance to peek at it. I'll be in IRC if you have
>> thoughts to share or things I should try.
> If you svn update from gdal trunk you should be able to build.  I'm also
> interested in trying an OSGeo4W package for INGRES support but it is
> getting a bit late tonight to push on that.
> Best regards,
> I set the clouds in motion - turn up   | Frank Warmerdam, warmerdam at pobox.com
> light and sound - activate the windows | http://home.gdal.org/warmerda
> and watch the world go round - Rush    | Geospatial Software Developer
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120126/b1cdc70d/attachment.html
