[gdal-dev] gdalwarp makes landcover files blocky when shrinking pixel size
Dutrieux, Loïc loic.dutrieux at wur.nl
Fri Jan 27 15:05:25 EST 2012
Hi John,
If I may add a bit to the discussion, applying resampling algorithm other than nearest neighbor to thematic layers such as land cover classification is not really recommended.
However, if you want to smoothen the edges of your resampling output, I would suggest a two steps approach:
- Resample using nearest neighbor.
- Apply a majority filter with a large moving window.
I cannot guarantee the result, but I guess it should work.
Best regards,
Loïc
-----Original Message-----
From: gdal-dev-bounces at lists.osgeo.org [mailto:gdal-dev-bounces at lists.osgeo.org] On Behalf Of John Twilley
Sent: vendredi 27 janvier 2012 20:58
To: Dmitry Baryshnikov
Cc: gdal-dev at lists.osgeo.org
Subject: Re: [gdal-dev] gdalwarp makes landcover files blocky when shrinking pixel size
None of those resampling methods are well-suited to classified rasters as far as I can tell.
The method that has worked best in the past was to take the majority of a number of the nearest neighbors.  The 'mode' algorithm in gdaladdo may do that, but I haven't checked the source code.
Jack.
mathuin at gmail dot com
2012/1/27 Dmitry Baryshnikov <polimax at mail.ru>:
> 27.01.2012 23:30, John Twilley пишет:
>> Cubic is fine for the elevation, but it doesn't work on the landcover.
>> which is the problem I originally mentioned.
>> Jack.
>> 2012/1/27 Dmitry Baryshnikov<polimax at mail.ru>:
>>> 27.01.2012 20:19, John Twilley пишет:
>>>> After retrieving the files and building VRTs from them, I run the
>>>> following gdalwarp commands:
>>>> gdalwarp -q -multi -t_srs "+proj=aea +datum=NAD83 +lat_1=29.5
>>>> +lat_2=45.5 +lat_0=23 +lon_0=-96 +x_0=0 +y_0=0 +units=m" -tr 6 6
>>>> +-te
>>>> 2002944 2271744 2016768 2288640 \
>>>>  -srcnodata -340282346638528859811704183484516925440 -dstnodata 0
>>>> ND302HT.vrt ND302HT.tif gdalwarp -q -multi -t_srs "+proj=aea
>>>> +-te
>>>>  -srcnodata 255 -dstnodata 11 L0102HT.vrt L0102HT.tif
>>>> The only differences between the lines are the nodata values.
>>>> Jack.
>>>> On Thu, Jan 26, 2012 at 22:49, Dmitry Baryshnikov<polimax at mail.ru>
>>>>  wrote:
>>>>> 27.01.2012 3:39, John Twilley пишет:
>>>>>> I am working with elevation and landcover data downloaded from
>>>>>> the USGS.  I use gdalwarp to convert the data to a much smaller
>>>>>> pixel. The elevation data works very nicely with cubic
>>>>>> resampling, but the only resampling that works at all for the
>>>>>> landcover data is nearest-neighbor and that's very blocky.  When
>>>>>> I last worked with landcover data, I used a majority algorithm
>>>>>> which produced smoother output -- but that algorithm is not implemented in gdalwarp.
>>>>>> I am looking over the source to gdalwarp to see how hard it is to
>>>>>> add a new algorithm.  Other than that, though, what options are
>>>>>> available to me?  Thanks in advance!
>>>>>> Jack.--
>>>>>> _______________________________________________
>>>>>> gdal-dev mailing list
>>>>>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
>>>>> Hi John,
>>>>> That is your command line string for gdalwarp?
>>>>> Best regards,
>>>>> Dmitry
>>> Hi John,
>>> Try to add "-r cubic" command parameter For example:
>>> +lat_2=45.5 +lat_0=23 +lon_0=-96 +x_0=0 +y_0=0 +units=m" -tr 6 6 -r cubic
>>> -te
>>> You can found additional parameters description here:
>>> http://www.gdal.org/gdalwarp.html
>>> I have tested -r parameter and it works.
>>> Best regards,
>>> Dmitry
> Hi John,
> You can use resampling methods:
> near: nearest neighbour resampling (default, fastest algorithm, worst
> interpolation quality).
> bilinear: bilinear resampling.
> cubic: cubic resampling.
> cubicspline: cubic spline resampling.
> lanczos: Lanczos windowed sinc resampling.
> And what method do you need?
> Best regards,
>    Dmitry
