[gdal-dev] HDF-EOS AIRS CO2 images without georeference using gdal_translate
Chaitanya kumar CH chaitanya.ch at gmail.com
Fri Jan 27 23:09:06 EST 2012
David,
gdalwarp should stop eliminating outliers when it can't find any more. But
to be sure you can pass the minimum number of GCPs. Also, the argument *
tolerance* is the tolerance in GCP's SRS units. Since the outliers are
indicated by (-9999,-9999) and our GCPs can go between -180 and 180,
anything between 360 and 9000 can be given as tolerance.
BTW, there is no need for -s_srs because we are using GCPs.
Do let us know how it goes.
On Sat, Jan 28, 2012 at 6:57 AM, David Ortiz <dvdov at yahoo.com> wrote:
> Chaitanya,
> This image have 329 GCPs and 41 of them are not outliers , can i put  -refine_gcps
> 329 41 in the command ?
> David A. Ortiz V
> *De:* Chaitanya kumar CH <chaitanya.ch at gmail.com>
> *Para:* David Ortiz <dvdov at yahoo.com>
> *CC:* "gdal-dev at lists.osgeo.org" <gdal-dev at lists.osgeo.org>
> *Enviado:* Jueves, enero 26, 2012 10:49 P.M.
> *Asunto:* Re: [gdal-dev] HDF-EOS AIRS CO2 images without georeference
> David,
> I checked the images I created now. The GCPs were not considered. So, I
> made sure they were used with gdalwarp.
> gdalwarp -s_srs "EPSG:4326" -t_srs "EPSG:4326" -refine_gcps 200 10 -of
> GTiff
> HDF4_EOS:EOS_SWATH:"AIRS.2008.03.12.228.L2.CO2_Sup.v5.4.11.0.CO2.T09254115637.hdf":CO2:CO2ret
> CO2_sup_Gtiff_EOS_warp.tif
> I used the -refine_gcps. It will help in excluding the dummy gcps pointing
> to (-9999,-9999,0). In this option, the number of minimum_gcps had to be
> given. I chose the number 10 based on the number of usable GCPs available.
> It should not be more than the number of usable GCPs. If I did not exclude
> the dummy gcps, I got black image.
> Also note that the output image dimensions changed.
> On Fri, Jan 27, 2012 at 7:26 AM, David Ortiz <dvdov at yahoo.com> wrote:
> Hi Chaitanya
> Applying gdalinfo -stats to input and output images i get coherent values
>  for statistics in both .img  and GTiff  images. The problem was in data
> display in GIS since QGIS show a Gtiff image with all pixel values equal to
> zero when i use "identify spatial objects" tool and ArcGIS  doesn't display
> it correctly , just two lines and no data, but gvSIG  allows see the
> appropriate values of CO2 amounts.
> However, neither the .img nor GTiff have geographical spatial reference in
> WGS84 datum coordinates. Even opening  subdatasets directly from hdf file with
> ArcGis , the images are missing georeference. As it is seen below, hdf
> image is between -133.57, -157.94 longitudes and 22.23, 45.88 latitudes. I
> mentioned HDF_SDS:UNKNOWN datasets on previous post because it have some
> info about coordinate reference system:
> SRS=GEOGCS["WGS 84",DATUM["WGS_1984",SPHEROID["WGS
> 84",6378137,298.257223563,AUTHORITY["EPSG","7030"]],TOWGS84[0,0,0,0,0,0,0],AUTHORITY["EPSG","6326"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.0174532925199433,AUTHORITY["EPSG","9108"]],AUTHORITY["EPSG","4326"]]
> Actually , when i load Geotiff generated with HEGTool (with other AIRS
> products) in any gis software , automatically have wgs84 Datum coordinates
> Here the results of gdalinfo command:
> 1. Input image
> gdalinfo -stats
> HDF4_EOS:EOS_SWATH:"/home/david/Descargas/pruebas/AIRS.2008.03.12.228.L2.CO2_Sup.v5.4.11.0.CO2.T09254115637.hdf":CO2:CO2ret
> Driver: HDF4Image/HDF4 Dataset
> Corner Coordinates:
> Upper Left  (    0.0,    0.0)
> Lower Left  (    0.0,   22.0)
> Upper Right (   15.0,    0.0)
> Lower Right (   15.0,   22.0)
> Center      (    7.5,   11.0)
> Band 1 Block=15x22 Type=Float32, ColorInterp=Gray
>   Min=379.197 Max=393.697
>   Minimum=379.197, Maximum=393.697, Mean=386.463, StdDev=3.071
>   NoData Value=-9999
>   Metadata:
>     STATISTICS_MAXIMUM=393.6969909668
>     STATISTICS_MEAN=386.46261742001
>     STATISTICS_MINIMUM=379.1969909668
>     STATISTICS_STDDEV=3.0709672735453
> 2.  with Geotiff output  image :
> gdalinfo -stats
>  /home/david/Descargas/pruebas/EOS/CO2_sup_Gtiff_EOS_traslate.tif
> Driver: GTiff/GeoTIFF
> Files: /home/david/Descargas/pruebas/EOS/CO2_sup_Gtiff_EOS_traslate.tif
>  /home/david/Descargas/pruebas/EOS/CO2_sup_Gtiff_EOS_traslate.tif.aux.xml
> Size is 15, 22
> Coordinate System is `'
> GCP Projection =
> GCP[  0]: Id=1, Info=
>           (0.5,0.5) -> (-9999,-9999,0)
> GCP[  1]: Id=2, Info=
>           (1.5,0.5) -> (-9999,-9999,0)
> GCP[  2]: Id=3, Info=
>           (2.5,0.5) -> (-9999,-9999,0)
> GCP[  3]: Id=4, Info=
>           (3.5,0.5) -> (-145.229995727539,23.3500003814697,0)
> GCP[  4]: Id=5, Info=
>           (4.5,0.5) -> (-9999,-9999,0)
> GROUP                  = HORIZONTALSPATIALDOMAINCONTAINER
>       GROUP                  = BOUNDINGRECTANGLE
>         OBJECT                 = EASTBOUNDINGCOORDINATE
>           NUM_VAL              = 1
>           VALUE                = -133.537399291992
>         END_OBJECT             = EASTBOUNDINGCOORDINATE
>         OBJECT                 = WESTBOUNDINGCOORDINATE
>           NUM_VAL              = 1
>           VALUE                = -157.941314697266
>         END_OBJECT             = WESTBOUNDINGCOORDINATE
>         OBJECT                 = SOUTHBOUNDINGCOORDINATE
>           NUM_VAL              = 1
>           VALUE                = 22.2317676544189
>         END_OBJECT             = SOUTHBOUNDINGCOORDINATE
>         OBJECT                 = NORTHBOUNDINGCOORDINATE
>           NUM_VAL              = 1
>           VALUE                = 45.889762878418
>         END_OBJECT             = NORTHBOUNDINGCOORDINATE
>       END_GROUP              = BOUNDINGRECTANGLE
>   INTERLEAVE=BAND
> Corner Coordinates:
> Center      (    7.5,   11.0)
>   NoData Value=-9999
>   Metadata:
> 3. .img image :
> gdalinfo -stats /home/david/Descargas/pruebas/EOS/CO2_sup_img_EOS.img
> Driver: HFA/Erdas Imagine Images (.img)
> Files: /home/david/Descargas/pruebas/EOS/CO2_sup_img_EOS.img
>        /home/david/Descargas/pruebas/EOS/CO2_sup_img_EOS.img.aux.xml
> Size is 15, 22
> GROUP                  = SPATIALDOMAINCONTAINER
>           NUM_VAL              = 1
>           NUM_VAL              = 1
>           NUM_VAL              = 1
>           NUM_VAL              = 1
> Corner Coordinates:
> Center      (    7.5,   11.0)
> Band 1 Block=64x64 Type=Float32, ColorInterp=Undefined
>   Description = Layer_1
>   NoData Value=-9999
>   Metadata:
>     LAYER_TYPE=athematic
> What is wrong?. I tried with gdal 1.8 and 1.9 with hdf4 support.
> Best regards.
> David Ortiz V.
Best regards,
Chaitanya kumar CH.
+91-9494447584
17.2416N 80.1426E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120128/6527483e/attachment.html
