[gdal-dev] Re: Problem with reading OziExplorer .map world files
Jukka Rahkonen jukka.rahkonen at mmmtike.fi
Mon Jan 30 02:22:40 EST 2012
AksakTimur <timchab <at> yahoo.com> writes:
> Yes, the files that I try to open are jpgs and bmps.
http://osgeo-org.1560.n6.nabble.com/Problem-with-reading-OziExplorer-map-world-files-tp4346806p4349081.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
I would guess that GDAL does not support .map files generally but only with the
OZF file format. http://gdal.org/frmt_ozi.html
You can have a try by converting a test image to OZF format with the Oziexploret
Image to Ozf tool. Perhaps GDAL finds georeferencing then.
-Jukka Rahkonen-
