[gdal-dev] gdalbuildvrt changes data when building VRT
John Twilley mathuin at gmail.com
Mon Jan 30 16:17:16 EST 2012
I'm using gdalbuildvrt as a simple way to merge adjoining data files.
Unfortunately, I'm noticing that some values change.  I've created a
simple test case where I make a VRT from a single GeoTIFF and compare
histograms before and after, and I've attached it to this message.
Can someone tell me why this is happening and how to avoid it?
Thanks!
Jack.
mathuin at gmail dot com
Type: application/octet-stream
Desc: not available
Url : http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120130/b4d887f9/typescript.obj
