[gdal-dev] How to read GML/GeoRSS directly from XML string?
Chaitanya kumar CH chaitanya.ch at gmail.com
Tue Jul 3 20:18:47 PDT 2012
Yingqi,
Though the GeoJSON driver allows for reading the data directly, it is more
like an exception. For consistent behavior between formats, you need to
read the data from a data source like a file or url.
You can create a temporary in-memory file of your data using the method
gdal.FileFromMemBuffer()
Example at http://www.gdal.org/ogr/drv_georss.html
There are also a few methods to import/export just the geometries. You can
import GML and WKT [1] and export to GML, KML and JSON[2].
[1]: http://www.gdal.org/ogr/classOGRGeometryFactory.html
[2]: http://www.gdal.org/ogr/classOGRGeometry.html
On Wed, Jul 4, 2012 at 3:34 AM, Yingqi Tang <anakintang at gmail.com> wrote:
> Hi,
> I am using OGR/GDAL to read GML/GeoRSS/GeoJSON from either local file or
> url, the sample code is like below
> inputDriver = ogr.GetDriverByName(inputDriverType)
> inputDataSource = inputDriver.Open(inputDataPath, 0);
> It seems that I can pass in the GeoJSON string directly like:
> inputDataSource = inputDriver.Open("
> {'type':'FeatureCollection','features':[{'type':'Feature','id':'OpenLayers.Feature.Vector_3449','properties':{},'geometry':{'type':'Polygon','coordinates':[[[-109.3449,
> 63.6328125
> ],[-112.5,35.5078125],[-85.078125,34.8046875],[-68.90625,39.7265625],[-68.203125,
> 67.1484375],[-109.6875,63.6328125
> ]]]},'crs':{'type':'OGC','properties':{'urn':'urn:ogc:def:crs:OGC:1.3:CRS84'}}},{'type':'Feature','id':'OpenLayers.Feature.Vector_07050618','properties':{},'geometry':{'type':'Polygon','coordinates':[[[-40.78125,
> 65.0390625
> ],[-40.078125,34.8046875],[-12.3449,25.6640625],[21.09375,17.2265625],[22.5,58.0078125],[-40.78125,
> 65.0390625]]]},'crs':{'type':'OGC','properties':{'urn':'urn:ogc:def:crs:OGC:1.3:CRS84'}}}]}",
> 0);
> But it doesn't seem to work with GML or GeoRSS, did I miss anything? So
> basically how can I read GML/GeoRSS directly from an XML string?
> Thanks
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Best regards,
Chaitanya kumar CH.
+91-9494447584
17.2416N 80.1426E
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120704/79a2c443/attachment.html>
