[gdal-dev] How to read GML/GeoRSS directly from XML string?
Yingqi Tang anakintang at gmail.com
Thu Jul 5 11:52:06 PDT 2012
Cool, adding ".json" doesn't solve the problem.
On Thu, Jul 5, 2012 at 11:47 AM, Even Rouault
<even.rouault at mines-paris.org>wrote:
> Le jeudi 05 juillet 2012 20:44:58, Yingqi Tang a écrit :
> > Hi Chaitanya,
> > GeoJSON does seem to be an exception, although the ogr driver can
> directly
> > read the GeoJSON string, the generic virtual memory file doesn't seem to
> > work:
> >     inputDataStr = "{geojson_string}";
> >     gdal.FileFromMemBuffer('/vsimem/temp', inputDataStr);
> >     inputDriver.Open('/vsimem/temp', 0);
> > Is that expected?
> Yes, the geojson driver only recognizes filenames ending with .json or
> .geojson, so use "/vsitem/temp.json" as a filename.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120705/3213415f/attachment.html>
