[gdal-dev] gdal_merge.py on large Tiff's. gdalwarp not working properly.
Chaitanya kumar CH chaitanya.ch at gmail.com
Sun Jul 8 00:18:14 PDT 2012
Aaron,
Can you provide some info about the images?
The gdalinfo output of each dataset and, if possible, the small images.
On Sun, Jul 8, 2012 at 12:08 PM, aphunter <a1hunter at ucsd.edu> wrote:
> Thanks for the suggestion. Unfortunately building the .vrt file as you
> suggested, and using gdal_translate, gives me the same fractured image that
> gdal_warp does. I am not sure why gdal_merge.py works properly while the
> others don't.
> http://osgeo-org.1560.n6.nabble.com/gdal-merge-py-on-large-Tiff-s-gdalwarp-not-working-properly-tp4986729p4986741.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Best regards,
Chaitanya kumar CH.
+91-9494447584
17.2416N 80.1426E
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120708/cbcd6622/attachment.html>
