[gdal-dev] gdal_merge.py on large Tiff's. gdalwarp not working properly.
Chaitanya kumar CH chaitanya.ch at gmail.com
Sun Jul 8 23:35:20 PDT 2012
Aaron,
This could be solved by using the nodata attribute. You can set the nodata
value in the source in the vrt file[1]. The vrt driver will ignore the
nodata areas.
If you have problem with that, rerun the gdalwarp operation and make sure
you get the nodata values.
Use the -srcnodata and -dstnodata options in gdalwarp.
[1]: http://www.gdal.org/gdal_vrttut.html
On Mon, Jul 9, 2012 at 7:49 AM, aphunter <a1hunter at ucsd.edu> wrote:
> Hi Jean-Claude. Thanks for the idea. Unfortunately it made the split a
> little
> larger. Is it possible to make the borders transparent, or remove them so
> the blending works properly as it does in gdal_merge.py?
> Thanks,
> Aaron
> http://osgeo-org.1560.n6.nabble.com/gdal-merge-py-on-large-Tiff-s-gdalwarp-not-working-properly-tp4986729p4986806.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Best regards,
Chaitanya kumar CH.
+91-9494447584
17.2416N 80.1426E
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120709/93f228b1/attachment.html>
