[gdal-dev] Label from OGR Style in a VRT output over a tiff in a geospatial PDF
Even Rouault even.rouault at mines-paris.org
Mon Jul 9 11:26:12 PDT 2012
>  From what I understand, LABEL(s:40pt,t:{NAME}) should use the NAME
> attribute field for the labels, but it is using "{NAME}" as the text.
Good catch. Support for that syntax was actually missing. I've just added it
in r24665
