[gdal-dev] Rasterlite and external overviews
Jukka Rahkonen jukka.rahkonen at mmmtike.fi
Mon Jul 9 12:39:05 PDT 2012
Unfortunately the nearest neighbour sampling of internal overviews of
Rasterlite tables yields pretty poor quality and no other sampling methods
are supported.
While trying external overviews I found two troubles. First one is that
it isimpossible to build external overviews if there has been internal
overviews in the table. Removing them with "gdaladdo -clean" does not
help, the message is still:
ERROR 6: Cannot add external overviews to a dataset with internal overviews
Overview building failed.
Another problem is not big. Gdaladdo just gives a faulty error message
first but it still creates external overviews. This is what gets printed
on the screen:
gdaladdo -ro RASTERLITE:addotest3.sqlite,table=t8000 2 4 8
ERROR 4: `addotest3.sqlite_t8000' does not exist in the file system,
and is not recognised as a supported dataset name.
0...10...20...30...40...50...60...70...80...90...100 - done.
It would be really good to have at least average method also for
internal overviews.
-Jukka Rahkonen-
