[gdal-dev] Label from OGR Style in a VRT output over a tiff in a geospatial PDF
Christy Nieman cnieman at dmsolutions.ca
Mon Jul 9 15:49:27 PDT 2012
Thanks Even.  Did a quick test and it looks good!
On 2012-07-09, at 2:26 PM, Even Rouault wrote:
>> From what I understand, LABEL(s:40pt,t:{NAME}) should use the NAME
>> attribute field for the labels, but it is using "{NAME}" as the text.
> Good catch. Support for that syntax was actually missing. I've just added it
> in r24665
