[gdal-dev] Can't convert .dgn file to shape file by using ogr2ogr
taibc taibc_coltech at yahoo.com
Wed Jul 11 22:05:58 PDT 2012
Dear Chaitanya,
Please find the attached .dgn file.
Thanks and regards,
Tai
 From: chaitanya_ch [via OSGeo.org] <ml-node+s1560n4987825h94 at n6.nabble.com>
To: taibc <taibc_coltech at yahoo.com>
Sent: Thursday, July 12, 2012 11:10 AM
Subject: Re: Can't convert .dgn file to shape file by using ogr2ogr
Tai,
Can you send me your dgn file?
On Thu, Jul 12, 2012 at 7:31 AM, taibc <[hidden email]> wrote:
Dear friends,
>I tried to convert .dgn file to shape files by using ogr2ogr with FWTools
>Shell as below:
>ogr2ogr -f "ESRI Shapefile" Dc16.shp Dc16.dgn
>but I got an bellow error:
>/Warning 6: Normalized/laundered field name: 'GraphicGroup' to 'GraphicGro'
>ERROR 1: Attempt to write non-linestring (POINT) geometry to ARC type
>shapefile.
>ERROR 1: Terminating translation prematurely after failed
>translation of layer elements (use -skipfailures to skip errors)/
>Are there anyone know how to fix this error ?
>PS: I am using Win 7
>Thanks and Regards,
>Tai
>View this message in context: http://osgeo-org.1560.n6.nabble.com/Can-t-convert-dgn-file-to-shape-file-by-using-ogr2ogr-tp4987817.html
>Sent from the GDAL - Dev mailing list archive at Nabble.com.
>_______________________________________________
>gdal-dev mailing list
>[hidden email]
>http://lists.osgeo.org/mailman/listinfo/gdal-dev
Best regards,
Chaitanya kumar CH.
+91-9494447584
17.2416N 80.1426E
[hidden email]
If you reply to this email, your message will be added to the discussion below:
http://osgeo-org.1560.n6.nabble.com/Can-t-convert-dgn-file-to-shape-file-by-using-ogr2ogr-tp4987817p4987825.html
To unsubscribe from Can't convert .dgn file to shape file by using ogr2ogr, click here.
NAML
View this message in context: http://osgeo-org.1560.n6.nabble.com/Can-t-convert-dgn-file-to-shape-file-by-using-ogr2ogr-tp4987817p4987829.html
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120711/4f6cd880/attachment-0001.html>
