[gdal-dev] Can't convert .dgn file to shape file by using ogr2ogr
taibc taibc_coltech at yahoo.com
Thu Jul 12 02:13:09 PDT 2012
Thanks Even Rouault,
I tried as you said, but still got the error:
/C:\dc16>ogr2ogr Dc16_lines.shp Dc16.dgn -where "ORG_GEOMETRY =
'LINESTRING'" -nl
n Dc16_lines
ERROR 1: Failed to identify field:ORG_GEOMETRY
Warning 6: Normalized/laundered field name: 'GraphicGroup' to 'GraphicGro'
ERROR 1: Attempt to write non-linestring (POINT) geometry to ARC type
shapefile.
ERROR 1: Terminating translation prematurely after failed
translation of layer elements (use -skipfailures to skip errors)/
Thanks and regards,
Tai
View this message in context: http://osgeo-org.1560.n6.nabble.com/Can-t-convert-dgn-file-to-shape-file-by-using-ogr2ogr-tp4987817p4987904.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
