[gdal-dev] Tiling aerial photos
Dmitry Baryshnikov polimax at mail.ru
Thu Jul 12 03:53:31 PDT 2012
12.07.2012 14:36, Paul Meems (Top-X) ?????:
> Thanks Even,
> http://www.gdal.org/gdalbuildvrt.html does seems very interesting.
> As I understand it, it will do the merging part (without actually
> merging).
> But it doesn't do the tiling part, right? Or is the vrt so optimized
> tiling is no longer necessary?
> Thanks,
> Paul
> 2012/7/12 Even Rouault <even.rouault at mines-paris.org
> <mailto:even.rouault at mines-paris.org>>
>     Selon "Paul Meems (Top-X)" <p.meems at topx-group.nl
>     <mailto:p.meems at topx-group.nl>>:
>     > Hi list,
>     > I have several aerial photos and I use MapWindow GIS to view them.
>     > MapWindow is already using GDAL v1.8
>     > Instead of loading each aerial photo as an individual layer I
>     want to
>     > create a local tiles store of the photos.
>     > I can then just load the tiles I need based on the scale and
>     view. This
>     > will most likely improve the performance.
>     > The process will be something like this:
>     > 1. Get the filenames of the photos
>     > 2. Merge them into one
>     > 3. Create tiles
>     > 4. Put the tiles in a SQLite database
>     > My first question: Is the above suggested process correct or
>     should I do it
>     > differently?
>     > My second question: What GDAL functions should I look into to
>     accomplish my
>     > process?
>     You could try to make a VRT from all your photos. It will be seen
>     as a single
>     GDAL dataset, and will take care of the burden of opening the
>     underlying photos
>     when needed. You can use the gdalbuildvrt utility to create the
>     VRT from the
>     photos.
>     > Thanks,
>     > Paul Meems
>     > The Netherlands
>     _______________________________________________
>     gdal-dev mailing list
>     gdal-dev at lists.osgeo.org <mailto:gdal-dev at lists.osgeo.org>
>     http://lists.osgeo.org/mailman/listinfo/gdal-dev
There is an interesting work connected aerial imagery:
http://trac.osgeo.org/gdal/wiki/Correlator
http://correlatorgsoc2012.blogspot.com/
Best regards,
     Dmitry
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120712/37804d7a/attachment.html>
