[gdal-dev] Memory leaks when using SQL queries with shapefiles
Pierluigi Guasqui guasqui at actgate.com
Fri Jul 13 04:22:52 PDT 2012
Il 13/07/2012 12.14, Even Rouault ha scritto:
> Selon Pierluigi Guasqui <guasqui at actgate.com>:
>> Hello,
>> I am experiencing a big memory allocation (with no subsequent memory
>> release) when using SQL queries with shapefiles. This is a sample code
>> that triggers this problem:
>>       OGRRegisterAll();
>>       // opening shapefile data source
>>       const char *fname = "path/to/shapefile.shp";
>>       OGRDataSource *poDS;
>>       poDS = OGRSFDriverRegistrar::Open( fname, FALSE );
>>       if( poDS == NULL )
>>           fprintf( stderr, "%s: could not open input file\n", fname );
>>           return -1;
>>       // creating the spatial filter
>>       OGRLineString regionPolygon;
>>       OGRRawPoint *pointsList = new OGRRawPoint[5];
>>       pointsList[0].x = -180; pointsList[0].y =  90;
>>       pointsList[1].x =  180; pointsList[1].y =  90;
>>       pointsList[2].x =  180; pointsList[2].y = -90;
>>       pointsList[3].x = -180; pointsList[3].y = -90;
>>       pointsList[4].x = -180; pointsList[4].y =  90;
>>       regionPolygon.setPoints(5, pointsList);
>>       delete[] pointsList;
>>       // executing the query
>>       const char *query = "SELECT * FROM table_name WHERE some_field LIKE
>> '%bla%' ORDER BY some_other_field";
>>       OGRLayer *rs = poDS->ExecuteSQL( query, &regionPolygon, NULL );
>>       // releasing memory
>>       poDS-> ReleaseResultSet( rs );
>>       OGRDataSource::DestroyDataSource( poDS );
>> With a 100.000 records shapefile "ExecuteSQL" has allocated over 300
>> MBytes of memory with no deallocation when calling "ReleaseResultSet".
>> The memory leak is triggered only when "ExecuteSQL" is called with a
>> spatial filter (even trivial as shown in the above code) and the SQL
>> query contains a 'WHERE' clause and an 'ORDER BY' clause. Is this a bug?
>> I am using GDAL 1.9.1 under Windows platform.
>> Any help would be really appreciated!
> Pierluigi,
> I have not a dev environmenet at the moment to investigate that, but could you
> open a ticket in GDAL Trac with all the details so it does not get lost ?
> Are you positive that, all other things unchanged, the presence of the spatial
> filter makes a difference ? I'm not sure how you check on Windows if the memory
> is really released (if you put your code in a while(1) {} loop, does the memory
> used by the process increase at each iteration ?).
> I also suspect that your spatial filter will not do what you would (probably)
> expect from it. The geometry of the filter is a LINESTRING, not a POLYGON. So it
> will only filter geometries that intersect the line, not geometries that are
> fully inside it.
> Best regards,
> Even
Even,
thank you for looking into my problem and for your reply. Yes I will
open a ticket in GDAL Trac.
I tried different test cases so I am sure that If I leave all other
things unchanged and just remove the use of the spatial filter I do not
see any memory leak. So it seems that the use of the spatial filter does
make the difference. Also, I tried the SQL query without the "WHERE"
clause or the "ORDER BY" clause and, again, I did not see any memory
leak. So also the use of "WHERE" clause *and* "ORDER BY" clause seem to
To check on Windows that memory is not released I put a "Sleep()" call
by the end of my code so I could check with Task Manager the process
memory allocation before the process quits. However, I added a
while(true) loop around my previous code:
     OGRRegisterAll();
     int loop_i = 1;
     while ( true )
         fprintf( stdout, "*** Loop %d... ", loop_i++ );
         fflush( stdout );
         if( poDS == NULL )
             return -1;
LIKE '%bla%' ORDER BY some_other_field";
         // releasing memory
         fprintf( stdout, "done\n" );
         fflush( stdout );
and I could get my process to allocate almost 1 GBytes of memory in just
3 loops! So, yes memory keeps on being allocating without being released
at each iteration.
Related to the use of LINESTRING filter instead of a POLYGON filter, yes
you are right: it will filter out features that intersect my line but
this is what I expect from the code from which I extrapolated the
example above. However, thank you for warning me!
Thank you!
Pierluigi Guasqui
Applied Coherent Technology Corp.
