[gdal-dev] ogr2ogr and reserved words
Even Rouault even.rouault at mines-paris.org
Fri Jul 13 06:41:39 PDT 2012
Hi Ivan,
> Is there any trick to avoid creating field names with reserved words? For
> example, a DBF from a shapefile can have field names like "long" and other
> formats may not like it.
It is up to the output driver to do whatever sanitizing it requires. This is
already done in a lot of drivers. The last recollection I have is in the FGBD
driver that modifies field names that match a list of reserved keywords. The
shapefile driver will also truncate too long field names, etc.. A bunch of RDBM
drivers have a LAUNDER creation option too. etc etc.
I suspect your question might be related to the OCI driver ? Perhaps it should
do something like the above if needed.
ogr2ogr is able to deal with drivers that have an implementation of
CreateField() that does a renaming/truncation/etc... of the source field name.
You also have the possibility to use the AS capability of OGR SQL to do the
renaming manually.
> Regards,
> Ivan
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
