[gdal-dev] How to compile gdal 1.9.1 from GDAL'S SVN ?
Ivan Lucena ivan.lucena at princeton-ma.us
Fri Jul 13 06:49:08 PDT 2012
But if you do want to build on Windows you can take a look on that wiki pages
http://trac.osgeo.org/gdal/wiki/BuildingOnWindows
http://trac.osgeo.org/gdal/wiki/MakeFileProjects
Setting up VS Express edition to build 64bit is a little trick though.
>  -------Original Message-------
>  From: Jean-Claude Repetto <jrepetto at free.fr>
>  To: gdal-dev at lists.osgeo.org
>  Subject: Re: [gdal-dev] How to compile gdal 1.9.1 from GDAL'S SVN ?
>  Sent: Jul 13 '12 08:28
>  On 07/13/2012 01:07 PM, laurent celati wrote:
>  > Hello,
>  > I would like compile gdal 1.9.1 from GDAL'S SVN then compile Qgis 1.8 from
>  > source using Gdal SVN version. I'm working on Windows 7 64bits.
>  > I am not in the habit of compiling software
>  > I did not used to compile software. Can you tell me how to do please?
>  Why don't you use the nightly builds avilables on this site :
>  http://www.gisinternals.com/sdk/ ?
>  Jean-Claude
>  _______________________________________________
>  gdal-dev mailing list
>  http://lists.osgeo.org/mailman/listinfo/gdal-dev
