[gdal-dev] New OGR driver to read OpenStreetMap .osm / .pbf files
Jeff McKenna jmckenna at gatewaygeomatics.com
Wed Jul 18 11:34:02 PDT 2012
> Even Rouault <even.rouault <at> mines-paris.org> writes:
>> Following the recent brainstorming with Jukka, I've pushed into trunk a driver
>> to read OpenStreetMap .osm / .pbf files .
Fascinating.  Actually I think once someone imports the points, lines,
polys into a DB, then (cool!) someone could then run the SQL script that
Mike Smith and I made recently
(https://github.com/mapserver/basemaps/blob/master/contrib/osm2pgsql-to-imposm-schema.sql)
that created generalized and specific tables, and then, could even (if
that someone wanted to publish through MapServer) run those tables
through the MapServer/basemaps utility to generate the magical mapfile
(https://github.com/mapserver/basemaps) !!!!
-jeff
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
