[gdal-dev] How to identify a point is belong to a polygon ?
taibc taibc_coltech at yahoo.com
Sat Jul 21 01:36:57 PDT 2012
Thanks Chaitanya,
I tried to install GEOS on Window.
But I got below error: NMAKE fatal error U1077 ....return code '0x2'
Detail is:
algorithm\LineIntersector.cpp(671) : error C3861: 'isnan': identifier not
found
algorithm\LineIntersector.cpp(672) : error C3861: 'isnan': identifier not
found
algorithm\LineIntersector.cpp(680) : error C3861: 'isnan': identifier not
found
algorithm\LineIntersector.cpp(681) : error C3861: 'isnan': identifier not
found
algorithm\LineIntersector.cpp(736) : error C3861: 'isnan': identifier not
found
algorithm\LineIntersector.cpp(737) : error C3861: 'isnan': identifier not
found
NMAKE : fatal error U1077: '"C:\Program Files\Microsoft Visual Studio
10.0\VC\BI
N\cl.EXE"' : return code '0x2'
Stop.
10.0\VC\BI
N\nmake.EXE"' : return code '0x2'
Stop.
chaitanya_ch wrote
> Tai,
> GDAL needs GEOS to perform these geometry functions. Make sure you install
> that.
> On Sat, Jul 21, 2012 at 12:19 PM, taibc <taibc_coltech@> wrote:
View this message in context: http://osgeo-org.1560.n6.nabble.com/How-to-identify-a-point-is-belong-to-a-polygon-tp4989501p4989779.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
