[gdal-dev] Oracle support available by default in any OSGeo software
Ivan Lucena ivan.lucena at princeton-ma.us
Mon Jul 23 05:26:54 PDT 2012
Hi Nicolas,
What operational system do you want to use?
Regards,
Ivan
>  -------Original Message-------
>  From: Nicolas Simon <nicolas.simon at spw.wallonie.be>
>  To: gdal-dev at lists.osgeo.org
>  Cc: vince.rogier at gmail.com
>  Subject: [gdal-dev] Oracle support available by default in any OSGeo software
>  Sent: Jul 23 '12 05:20
>  Hi ,
>  I't very frustrating, each time I would like to use OSGeo software
>  (GDAL/OGR, QGIS,
) they don't support oracle database. Every time,
>  everything should be recompiled from source with oracle support enabled. A
>  long and not easy process
>  The reason usually evoked for this situation, is that Oracle build
>  needs Oracle files that aren't freely redistributable. Ok It's a good
>  reason.
>  I found a library, called OCILIB (<[LINK:
>  http://orclib.sourceforge.net/] http://orclib.sourceforge.net/>), that
>  enable your software to dynamically connect to your oracle database. This
>  library does not require any oracle library to compile. It's available on
>  any platform where oracle client is available and it licensed with LGPL.
>  So it seems possible to create an OGR driver for Oracle, based on
>  OCILIB, that doesn't require any Oracle copyrighted files.
>  So what I propose is to develop, with the help of any volunteer,
>  this kind of driver.
>  But before going further, I would like to know if it seems to you a
>  good way to have Oracle support available by default in any OSGeo software
>  Depending of your answers, I 'll come back to ask you how it's the
>  best way to do that ?
>  Thanks a lot
>  Nicolas Simon
>  _______________________________________________
>  gdal-dev mailing list
>  [LINK: compose.php?to=gdal-dev at lists.osgeo.org] gdal-dev at lists.osgeo.org
>  [LINK: http://lists.osgeo.org/mailman/listinfo/gdal-dev]
