[gdal-dev] New OGR driver: Imageset (Tamas Szekeres)
Daniel Clewley daniel.clewley at gmail.com
Mon Jul 23 08:16:30 PDT 2012
Hi Tamas,
Sounds like a great idea. I don't know if it's of use but I recently put
together a python script to create KMZ files of geotagged photos using
the Python Imaging Library to read EXIF data. It also exports a list of
photos and coordinates as a CSV file, for loading into a GIS. You could
use OGR to output a vector data source instead.
The script can be downloaded from here:
http://dropbox.aber.ac.uk/?KJHsTqst
Thanks,
Dan
On Mon, 23 Jul 2012 09:51:14 +0200, Tamas Szekeres wrote:
 > Hi All,
 > We're thinking about implementing a new OGR driver which would
 > represent a set of images as a vector data source. The images are
 > taken from any GPS compatible mobile device, and each picture would be
 > represented as a point feature, the positions would be extracted from
 > the exif information. The file name and path would be provided as an
 > attribute for each feature. This data source could then be used by
 > higher level apps to provide symbols at the picture locations in the
 > map and display the picture when the feature is selected. The driver
 > would definitely use GDAL to extract information about the provided
 > images.
 > I'm not sure whether we already have some kind of alternative solution
 > to this, let me know if you know about any. Further ideas about this
 > topic would also be helpful.
 > Best regards,
 > Tamas
