[gdal-dev] encoding problem when reading DXF file
dequan chen cdqrain at gmail.com
Mon Jul 23 18:37:05 PDT 2012
hi all,
I download the latest gdal-19-1600-core.msi from
http://www.gisinternals.com/sdk and installed, then copy gdal_csharp.dll,
ogr_csharp.dll, osr_csharp.dll etc to read .DXF file. But it has the problem
of charactor encoding. My DXF file contains chinese charactor that code is
GB2312. If i use DLLs from FWTOOLS, the charactor encoding correctly, but i
cannot to run my compiled EXE (both debug and release versions). The
application just crashes.
What more work should i do ? thanks advanced.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120724/4440b2ca/attachment.html>
