[gdal-dev] How to identify a point is belong to a polygon ?
Chaitanya kumar CH chaitanya.ch at gmail.com
Mon Jul 23 22:43:36 PDT 2012
Tai,
The environment variables can be set at the command prompt temporarily
using
SET LD_LIBRARY_PATH=C:\path\to\gdal\libraries
SET GDAL_DATA=C:\path\to\gdal\libraries\data
You can set them in the project settings in VC++. I don't know how.
You can also set them system wide at MyComputer->Settings.
On Tue, Jul 24, 2012 at 9:50 AM, taibc <taibc_coltech at yahoo.com> wrote:
> Thanks Chaitanya,
> I haven't set LD_LIBRARY_PATH and GDAL_DATA yet.
> Do you know how to set them on Visual C++ 2010 ?
> Kind regards,
> Tai
> *From:* chaitanya_ch [via OSGeo.org] <[hidden email]<http://user/SendEmail.jtp?type=node&node=4990251&i=0>
> *To:* taibc <[hidden email]<http://user/SendEmail.jtp?type=node&node=4990251&i=1>>
> *Sent:* Tuesday, July 24, 2012 10:38 AM
> *Subject:* Re: How to identify a point is belong to a polygon ?
>  Tai,
> If your rebuild was successful with geos, the only reason for you to get
> the error is that the application is accessing the wrong libraries
> somewhere in your system. Do a clean rebuild and make sure the
> LD_LIBRARY_PATH and GDAL_DATA are set correctly.
> On Tue, Jul 24, 2012 at 7:37 AM, taibc <[hidden email]> wrote:
> Thanks Mateusz,
> I edited the nmake.opt by adding below lines:
> GEOS_DIR = C:/geos-3.3.5
> GEOS_LIB = $(GEOS_DIR)/src/geos_c_i.lib
> GEOS_CFLAGS = -I$(GEOS_DIR)/capi -I$(GEOS_DIR)/include/geos -DHAVE_GEOS
> Then, I rebuilt GDAL, but still got the error: "GEOS support not enable".
> Kind regards,
> Tai
> *From:* Mateusz Loskot [via OSGeo.org <http://osgeo.org/>] <[hidden email]<http://user/SendEmail.jtp?type=node&node=4990235&i=0>
> *To:* taibc <[hidden email]<http://user/SendEmail.jtp?type=node&node=4990235&i=1>>
> *Sent:* Monday, July 23, 2012 5:56 PM
>  On 23 July 2012 11:52, taibc <[hidden email]> wrote:
> > I installed GEOS succesfful, and copy file geos.dll into my project. But
> I
> > still got the error: "GEOS support not enable" when using the method
> > "Within"
> > Are there something wrongs ?
> You need to edit nmake.opt and rebuild GDAL.
> Check this thread:
> http://lists.osgeo.org/pipermail/gdal-dev/2010-March/023829.html
> Best regards,
> Mateusz Loskot, http://mateusz.loskot.net
> gdal-dev mailing list
> [hidden email]
>  If you reply to this email, your message will be added to the discussion
> below:
> http://osgeo-org.1560.n6.nabble.com/How-to-identify-a-point-is-belong-to-a-polygon-tp4989501p4990029.html
>  To unsubscribe from How to identify a point is belong to a polygon ?, click
> here.
> NAML<http://osgeo-org.1560.n6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
> View this message in context: Re: How to identify a point is belong to a
> polygon ?<http://osgeo-org.1560.n6.nabble.com/How-to-identify-a-point-is-belong-to-a-polygon-tp4989501p4990235.html>
> Sent from the GDAL - Dev mailing list archive<http://osgeo-org.1560.n6.nabble.com/GDAL-Dev-f3742093.html>at
> Nabble.com <http://nabble.com/>.
> [hidden email]
> Best regards,
> Chaitanya kumar CH.
> +91-9494447584
> 17.2416N 80.1426E
> [hidden email]
> below:
> http://osgeo-org.1560.n6.nabble.com/How-to-identify-a-point-is-belong-to-a-polygon-tp4989501p4990248.html
> here.
> polygon ?<http://osgeo-org.1560.n6.nabble.com/How-to-identify-a-point-is-belong-to-a-polygon-tp4989501p4990251.html>
> Sent from the GDAL - Dev mailing list archive<http://osgeo-org.1560.n6.nabble.com/GDAL-Dev-f3742093.html>at Nabble.com.
> gdal-dev at lists.osgeo.org
Best regards,
Chaitanya kumar CH.
+91-9494447584
17.2416N 80.1426E
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120724/f0ff1784/attachment.html>
