[gdal-dev] encoding problem when reading DXF file
Dmitry Baryshnikov polimax at mail.ru
Wed Jul 25 01:19:32 PDT 2012
25.07.2012 11:11, dequan chen ?????:
> hi Dmitry
> Should i need to download source code and modify a little, then build
> myself ? I'm not familiar in C++. :-(
> but I want to know whether the latest version has revised the issue,
> and where to get the gdal installation ?
> thanks a lot.
It's enough to create a ticket in http://trac.osgeo.org/gdal/ (see
http://trac.osgeo.org/gdal/newticket for details)
Also your buggy data in attach is welcome.
<http://trac.osgeo.org/gdal/>
>     Hi Dequan,
>     It seems to me that is the similar issue
>     http://trac.osgeo.org/gdal/ticket/4650
>     Check TestCapability method of DXF driver
>     Best regards,
>         Dmitry
>     _______________________________________________
>     gdal-dev mailing list
>     gdal-dev at lists.osgeo.org <mailto:gdal-dev at lists.osgeo.org>
>     http://lists.osgeo.org/mailman/listinfo/gdal-dev
 >> Why the FWTools2.4.7 can encoding DXF lable correctly, but the
latest build gdal is not support ?
In FWTools is present previous GDAL version. In GDAL 1.9.x there was a
move to UTF encoding.
You can play with DXF_ENCODING option
(http://trac.osgeo.org/gdal/wiki/ConfigOptions).
Best regards,
     Dmitry
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120725/9e7be6c7/attachment-0001.html>
