[gdal-dev] Question about adding features to ESRI Shapefile without Geometry
Even Rouault even.rouault at mines-paris.org
Wed Jul 25 13:22:52 PDT 2012
Le mercredi 25 juillet 2012 22:09:32, Sebastian D'Agostino a écrit :
> Hi Even,
> Thank you very much for your reply.
> I couldn't provide code for my question because it isn't standalone code
> (I'm using a couple of classes in a big C++ project).
Yes my suggestion was that you try to isolate the few lines of codes that are
spread among your big project into something small and standalone so that
people you are asking the question have a chance to investigate ;-)
> Besides, I'm doing it in the reverse order:
> lyr.CreateFeature(feat)
> feat.SetGeometry(None)
Ah, that won't work ! Any change you make on the feature after calling
CreateFeature() will not be saved into the shapefile. You need to do it before.
Or if you do it afterwards, you'll need to call lyr.SetFeature(feat) to update
the on-file content (but if you can set the feature completely before calling
CreateFeature(), that will be more efficient of course)
