[gdal-dev] how to set proxy authentication method for WMS
Livneh Yehiyam yehil at rafael.co.il
Mon Jul 30 07:42:30 PDT 2012
Hi
Is it possible to set the proxy authentication method to NTLM using either the config options or the environment?
I noticed that it is possible to set the proxy server and user:password, and also the http authentication method, but I couldn't find the proxy setting.
The curl options that needs to be set is CURLOPT_PROXYAUTH
Thanks
Yehiyam Livneh
This message (including any attachments) issued by RAFAEL- ADVANCED DEFENSE SYSTEMS LTD.
(hereinafter "RAFAEL") contains confidential information intended for a specific individual and purpose, may
constitute information that is privileged or confidential or otherwise protected from disclosure. If you are not
the intended recipient, you should contact us immediately and thereafter delete this message from your
system. You are hereby notified that any disclosure, copying, dissemination, distribution or forwarding of this
message, or the taking of any action based on it, is strictly prohibited. If you have received this e-mail in error,
please notify us immediately by e-mail mailto:lawraf at rafael.co.il and completely delete or destroy any and all
electronic or other copies of the original message and any attachments thereof.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120730/1f56f1f9/attachment.html>
