[gdal-dev] gdalbuildvrt problem with heterogenous band characteristics
Casper Børgesen (CABO) CABO at NIRAS.DK
Mon Jul 30 10:31:05 PDT 2012
Hi!
I'm trying to create a VRT file from 4 GeoTIFFs using gdalbuildvrt. Three of the GeoTIFFs are created using OrthoVista and the last one created with an earlier version of the same program. When I run gdalbuildvrt I get the following error message when I try to add the file created by the early version:
Warning 6: gdalbuildvrt does not support heterogenous band characteristics. Skipping...
Running gdalinfo on the 4 files I see only a difference in the metadata section (and of course in the coordinates).
In the following is the band information from two of the files:
[From new version]
Band 1 Block=6250x20 Type=Byte, ColorInterp=Red
  Overviews: 1024x1024
Band 2 Block=6250x20 Type=Byte, ColorInterp=Green
Band 3 Block=6250x20 Type=Byte, ColorInterp=Blue
Band 4 Block=6250x20 Type=Byte, ColorInterp=Undefined
[From earlier version]
To me they seem identical and I can display them both using QGis 1.8. I guess that the difference is deeper inside the TIFFs than gdalinfo informs me about - what can I do to avoid this problem?
Regards Casper
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120730/1b3c9ff8/attachment.html>
