[gdal-dev] gdalbuildvrt problem with heterogenous band characteristics
Chaitanya kumar CH chaitanya.ch at gmail.com
Tue Jul 31 07:15:34 PDT 2012
Casper,
You can edit the vrt file in a text editor. Just make a copy of the
elements of one file and change them according to the fourth file. You can
refer to the VRT tutorial[1] if you have any doubts.
Can you provide the full gdalinfo report of the two files?
[1]: http://www.gdal.org/gdal_vrttut.html
On Tue, Jul 31, 2012 at 7:16 PM, Casper Børgesen (CABO) <CABO at niras.dk>wrote:
>  What do you mean by manually? I run gdalbuildvrt using the command line,
> so I don’t understand how it can be done more manually J****
> gdalbuildvrt myfile.vrt file1.tif file2.tif file3.tif file4.tif****
> I have tried using an old version of gdalinfo (1.7.0) and it gives tells
> me that my first 3 bands in the old file contains a mask flag:****
> Mask Flags: PER_DATASET ALPHA****
> This flag is not present in the 3 new files. Could this be the reason? ***
> Btw. my normal version of gdal is 1.9.****
> Regards, Casper****
> *From:* Chaitanya kumar CH [mailto:chaitanya.ch at gmail.com]
> *Sent:* 31. juli 2012 15:30
> *To:* Casper Børgesen (CABO)
> *Cc:* gdal-dev at lists.osgeo.org
> *Subject:* Re: [gdal-dev] gdalbuildvrt problem with heterogenous band
> characteristics****
> Casper,
> This message should not appear unless there is a difference in the band
> data type, colour interpretation or the band order.
> Can you check if manually adding the old file works?****
> On Mon, Jul 30, 2012 at 11:01 PM, Casper Børgesen (CABO) <CABO at niras.dk>
> wrote:****
> Hi! ****
> I’m trying to create a VRT file from 4 GeoTIFFs using gdalbuildvrt. Three
> of the GeoTIFFs are created using OrthoVista and the last one created with
> an earlier version of the same program. When I run gdalbuildvrt I get the
> following error message when I try to add the file created by the early
> version: ****
> Warning 6: gdalbuildvrt does not support heterogenous band
> characteristics. Skipping...****
> Running gdalinfo on the 4 files I see only a difference in the metadata
> section (and of course in the coordinates). ****
> In the following is the band information from two of the files:****
> [From new version]****
> Band 1 Block=6250x20 Type=Byte, ColorInterp=Red****
>   Overviews: 1024x1024****
> Band 2 Block=6250x20 Type=Byte, ColorInterp=Green****
> Band 3 Block=6250x20 Type=Byte, ColorInterp=Blue****
> Band 4 Block=6250x20 Type=Byte, ColorInterp=Undefined****
> [From earlier version]****
> To me they seem identical and I can display them both using QGis 1.8. I
> guess that the difference is deeper inside the TIFFs than gdalinfo informs
> me about – what can I do to avoid this problem?****
> Regards Casper****
> gdal-dev mailing list
> http://lists.osgeo.org/mailman/listinfo/gdal-dev****
> Best regards,
> Chaitanya kumar CH.
> +91-9494447584
> 17.2416N 80.1426E****
Best regards,
Chaitanya kumar CH.
+91-9494447584
17.2416N 80.1426E
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120731/18e2cef4/attachment.html>
