[gdal-dev] GeoPDF (TM) vs. GeoSpatial PDF
David Strip gdal at stripfamily.net
Sat Jun 2 15:16:51 PDT 2012
Jukka's posting earlier today has made me aware that GDAL will now write
a geospatial PDF. Is it also capable of writing a geoPDF (which is a
trademark of TerraGo, but there is an OGC standard, so possibly it's
legal to create them)? When used in conjunction with the (free) TerraGo
toolbar, the geoPDF provides many more capabilities than a geo-spatial
pdf, especially if the pdf "modify" permission is set. From the looks of
it, the main difference between a geospatial PDF and a geoPDF is that
the latter contains a dictionary object LGIdict which contains the
projection, the coordinate transform to the page, and that sort of
thing. In fact, it will support multiple data frames on the same page.
