[gdal-dev] Convert DBX/SHP to JSON using ogr2ogr
Even Rouault even.rouault at mines-paris.org
Sun Jun 3 10:21:22 PDT 2012
> Can you tell how I can determine the source SRS from the files? Is
> that possible?
Sometimes, you have an associated .prj file that contains the SRS. If the file
is not present, then you must guess it.
