[gdal-dev] Reading a NetCDF file with python (not recognised as a supported dataset name
Etienne Tourigny etourigny.dev at gmail.com
Fri Jun 8 08:31:59 PDT 2012
with commandline and/or python?
I can do both fine using gdal-1.9.1 from osgeo4w (32bit), haven't
tried Tamas' build yet
On Fri, Jun 8, 2012 at 12:08 PM, Kyle Shannon <KShannon at gcs-research.com> wrote:
> Etienne, Rutger,
> I can reproduce on windows with 32 bit 1.9 branch and 1.9.1 from Tamas' site.  In fact, I couldn't open any datasets.
> kss
> -----Original Message-----
> From: gdal-dev-bounces at lists.osgeo.org [mailto:gdal-dev-bounces at lists.osgeo.org] On Behalf Of Etienne Tourigny
> Sent: Friday, June 08, 2012 9:10 AM
> To: Rutger
> Cc: gdal-dev at lists.osgeo.org
> Subject: Re: [gdal-dev] Reading a NetCDF file with python (not recognised as a supported dataset name
> Rutger,
> There should not be any difference when using the python bindings. If gdalinfo can read it the python bindings should also.
> I cannot reproduce your problem using gdal-1.9.1 under linux.  Which exact version are you using?
> By the way, the vrtfile in unnecessary, because GDAL's Open accepts the NETCDF:file.nc:variable syntax.
> Try adding this to your script and send the result back here gdal.SetConfigOption( 'CPL_DEBUG', 'ON' )
> also try gdal_info.exe -stats
> NETCDF:LPRM-TMI_L3_DY_SOILM3_V001-20120411T144114Z_20120102.nc:soil_moisture_x
> this actually reads the file contents and not just the metadata. If it fails then something is wrong.
> you should see
>    STATISTICS_MAXIMUM=99
>    STATISTICS_MEAN=21.746993313128
>    STATISTICS_MINIMUM=0
>    STATISTICS_STDDEV=20.100893016522
> Etienne
> On Fri, Jun 8, 2012 at 9:00 AM, Rutger <kassies at gmail.com> wrote:
>> Dear list,
>> I am trying to open a NetCDF file with the Python bindings. My GDAL
>> 1.9 build (Win32 from Tamas) shows the NetCDF driver when i run
>> "gdalinfo --formats", so it should be possible.
>> When using the pre-build command-line utilities all works well. But
>> when i move to Python i get the message:
>> /" ... does not exist in the file system, and is not recognised as a
>> supported dataset name."/ I dont have the slightest clue about what
>> i'm doing wrong.
>> I have simplified the problem to 3 steps:
>> 1. Use gdal_translate to select a subdataset and output to VRT 2. Read
>> the VRT in Python with gdal.Open() 3. Use gdal_translate to convert
>> the VRT to a Geotiff
>> Step 1 & 3 work well, but 2 fails. Is there some limitation of the
>> Python bindings regarding NetCDF? The script runs fine if i replace
>> the NetCDF with a Geotiff file.
>> Any help would be appreciated.
>> An example NetCDF i used can be found at:
>> ftp://hydro1.sci.gsfc.nasa.gov/data/s4pa/WAOB/LPRM_TMI_DY_SOILM3.001/2
>> 012/05/
>> 012/05/
>> Below is the Python script i have used for exploring the issue:
>> import os
>> try:
>>    from osgeo import gdal
>> except ImportError:
>>    import gdal
>> netcdffile =
>> "NETCDF:LPRM-TMI_L3_DY_SOILM3_V001-20120411T144114Z_20120102.nc:soil_moisture_x"
>> vrtfile = "LPRM-TMI_L3_DY_SOILM3_V001-20120411T144114Z_20120102.vrt"
>> tiffile = "LPRM-TMI_L3_DY_SOILM3_V001-20120411T144114Z_20120102.tif"
>> # 1: convert the netcdf to vrt externally (works well)
>> os.system('gdal_translate -of "VRT" ' + netcdffile + ' ' + vrtfile)
>> # 2: try to open the vrt in Python (fails at .ReadAsArray) dsin =
>> gdal.Open(vrtfile)
>> if not dsin is None:
>>  indata = dsin.ReadAsArray(0, 0, dsin.RasterXSize, dsin.RasterYSize)
>> # 3: convert the same vrt to a tif externally (works well)
>> os.system('gdal_translate ' + vrtfile + ' ' + tiffile)
>> Regards,
>> Rutger
>> View this message in context:
>> http://osgeo-org.1560.n6.nabble.com/Reading-a-NetCDF-file-with-python-
>> not-recognised-as-a-supported-dataset-name-tp4979943.html
>> Sent from the GDAL - Dev mailing list archive at Nabble.com.
>> gdal-dev mailing list
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
