[gdal-dev] Reading a NetCDF file with python (not recognised as a supported dataset name
Rutger
kassies at gmail.com
Fri Jun 8 13:56:36 PDT 2012
Hey,
Thank you all for the replies, i really appreciate the help.
@Anton, i have tried many different ways of refering to the file. Full path,
file only, back and forward slashes, double slashes etc. All have the same
result. I also would expect this to be platform dependent, but not file
format dependent. So for a NetCDF file it should be similar as for Geotiff
etc. The NETCDF prefix and subdataset are format specific, so this might be
an issue. But if this is wrong, i would suspect the commandline utilities to
be failing as well.
@Etienne, Running gdalinfo with stats gives me exactly the same values as
you, till the last decimal. This confirms that both the file is fine
(gdal-proof), and that the pre-build command-line utilities are working as
supposed to.
Turning on 'CPL_DEBUG' (and adding the -q to supress progress) for the
previous posted script results in:
/D:\Projects\Python\TRMM_soilm>python debug.py
GDAL: GDALOpen(LPRM-TMI_L3_DY_SOILM3_V001-20120503T175233Z_20120501.vrt,
this=01883C90) succeeds as VRT.
ERROR 4:
`NETCDF:LPRM-TMI_L3_DY_SOILM3_V001-20120503T175233Z_20120501.nc:soil_moisture_x'
does not exist in the file system,
and is not recognised as a supported dataset name.
GDAL: GDALClose(LPRM-TMI_L3_DY_SOILM3_V001-20120503T175233Z_20120501.vrt,
this=01883C90)
GDAL:
GDALClose(NETCDF:LPRM-TMI_L3_DY_SOILM3_V001-20120503T175233Z_20120501.nc:soil_moisture_x,
this=01884388)/
Besides the earlier error still being present i dont see anything which can
be an indication of the problem.
If anyone has any other ways of debugging this, i would appreciate it.
Regards,
Rutger
View this message in context: http://osgeo-org.1560.n6.nabble.com/Reading-a-NetCDF-file-with-python-not-recognised-as-a-supported-dataset-name-tp4979943p4980067.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
