[gdal-dev] [NEW] Multi-threaded warping
Seth Price seth at pricepages.org
Sun Jun 10 16:29:53 PDT 2012
If you tell OpenCL to target the CPU, it will produce a multiprocessor implementation instead of GPU.
~Seth
via iPhone
On Jun 10, 2012, at 3:52 PM, Even Rouault <even.rouault at mines-paris.org> wrote:
> Le dimanche 10 juin 2012 23:44:54, Yogesh Dahiya a écrit :
>> As far I know gdal1.9 has integrated opencl so we can parallelize by
>> setting it right.
>> So what exactly is your addition.
>> By the way I tried opencl case and was able to get 16x over general case
>> for lanczos for image of 16000*16000
> (Replying to list too, as others might have the same question)
> Yes indeed, GDAL 1.9 can use OpenCL and this implementation is of course still
> available.
> Unfortunately, AFAIK, there is not yet any working OpenSource OpenCL
> implementation (and my experience with some proprietary OpenCL implementation
> has not always been convincing, like the GUI being totally unresponsive during
> the processing).
> The new multi-threaded implementation just uses traditional multi-threading
> technics that are available on all platforms where GDAL can run.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
