[gdal-dev] Using Java bindings of GDAL library : UnsatisfiedLinkError
Even Rouault even.rouault at mines-paris.org
Mon Jun 11 11:00:39 PDT 2012
> /rhel5pdi/home/kdeshpan/gdal_java/swig/java/libogrjni.so: wrong ELF class:
> ELFCLASS64 (Possible cause: architecture word width mismatch)
That's pretty informative, isn't it ? Sounds like you are mixing a 64bit Java
with a 32bit GDAL build, or the reverse
