[gdal-dev] Ogr2ogr from Spatialite into PostGIS stops to non-ASCII character
Jeff McKenna jmckenna at gatewaygeomatics.com
Wed Jun 13 05:09:25 PDT 2012
On 12-06-13 8:58 AM, Jukka Rahkonen wrote:
> Hi,
> How could I prevent the following problem:
> ERROR 1: INSERT command for new feature failed.
> ERROR:  invalid byte sequence for encoding "UTF8": 0xc56b
> Command: INSERT INTO "test_table" ("wkb_geometry" , "address",
> "osoite") VALUES ('0101000020FB0B0000AB1109023B190841634688040C595941'
> ::GEOMETRY, 'Jurmo ┼kershamn', 8) RETURNING "ogc_fid"
> ERROR 1: Terminating translation prematurely after failed
> translation of layer test_table (use -skipfailures to skip errors)
> I believe that my Spatialite db is in order and uses UTF-8 internally. The
> target PostGIS db is also using UTF-8.
> I am on a Windows XP machine with Finnish locale settings.
Hmm I have had to use the magical "-W" switch before with shp2pgsql to
specify encoding; I wonder if with ogr2ogr you should pass a "-sql"
switch with something like "SET CLIENT_ENCODING to UTF8" ?  But I
haven't tested that.
-jeff
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
