[gdal-dev] convert .tif/.tfwx/.aux.xml to a geotiff?
geomartino geomartino at gmail.com
Mon Jun 18 08:03:42 PDT 2012
.tfwx
4,2446168308058878
-0,12113356893358353
-0,12348388948051223
-4,2263807340657786
323886,87950403825
5182071,0717815552
.aux.xml
<PAMDataset>
  <Metadata/>
  <Metadata domain="xml:ESRI" format="xml">
    <GeodataXform xsi:type="typens:PolynomialXform"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:xs="http://www.w3.org/2001/XMLSchema"
xmlns:typens="http://www.esri.com/schemas/ArcGIS/10.0">
      <PolynomialOrder>1</PolynomialOrder>
      <SpatialReference xsi:type="typens:ProjectedCoordinateSystem">
<WKT>PROJCS["NAD_1927_UTM_Zone_19N",GEOGCS["GCS_North_American_1927",DATUM["D_North_American_1927",SPHEROID["Clarke_1866",6378206.4,294.9786982]],PRIMEM["Greenwich",0.0],UNIT["Degree",0.0174532925199433]],PROJECTION["Transverse_Mercator"],PARAMETER["False_Easting",500000.0],PARAMETER["False_Northing",0.0],PARAMETER["Central_Meridian",-69.0],PARAMETER["Scale_Factor",0.9996],PARAMETER["Latitude_Of_Origin",0.0],UNIT["Meter",1.0],AUTHORITY["EPSG",26719]]</WKT>
        <XOrigin>-5121000</XOrigin>
        <YOrigin>-9998000</YOrigin>
        <XYScale>450450052.74759901</XYScale>
        <ZOrigin>-100000</ZOrigin>
        <ZScale>10000</ZScale>
        <MOrigin>-100000</MOrigin>
        <MScale>10000</MScale>
        <XYTolerance>0.001</XYTolerance>
        <ZTolerance>0.001</ZTolerance>
        <MTolerance>0.001</MTolerance>
        <HighPrecision>true</HighPrecision>
        <WKID>26719</WKID>
      </SpatialReference>
      <SourceGCPs xsi:type="typens:ArrayOfDouble">
        <Double>4.8908512645451037</Double>
        <Double>25.730248842109091</Double>
        <Double>16.685287664469797</Double>
        <Double>25.294638277962804</Double>
        <Double>4.6809492973132762</Double>
        <Double>6.0210986253641749</Double>
        <Double>17.233821111329988</Double>
        <Double>6.366754659536582</Double>
      </SourceGCPs>
      <TargetGCPs xsi:type="typens:ArrayOfDouble">
        <Double>330000</Double>
        <Double>5178000</Double>
        <Double>345000</Double>
        <Double>5177000</Double>
        <Double>329000</Double>
        <Double>5153000</Double>
      </TargetGCPs>
    </GeodataXform>
  </Metadata>
</PAMDataset>
View this message in context: http://osgeo-org.1560.n6.nabble.com/gdal-dev-convert-tif-tfwx-aux-xml-to-a-geotiff-tp4981730p4982138.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
