[gdal-dev] MSSQL Spatial and UTF-8
Gunter Becker gunter.becker at csogis.de
Tue Jun 19 04:29:07 PDT 2012
I'm trying to import a shapefile via ogr2ogr into a SQL Server 2008 DB. When
looking at the created table I realised that some columns have some ugly
columnnames. Same to the strings in the data of this table. The problem is
caused by some special characters (german umlauts) in the dataset.
Using ogr2ogr with other drivers (ex. SQLite, PostGIS) to import this
shapefile works as expected so that I think it is a problem with the "MSSQL
Spatial"-driver.
Is there any driver related setting I can make to force UTF-8 import into
SQL Server?
Thanks, Gunter
View this message in context: http://osgeo-org.1560.n6.nabble.com/MSSQL-Spatial-and-UTF-8-tp4982371.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
