[gdal-dev] zonal statistics with gdal
Joaquim Luis jluis at ualg.pt
Wed Jun 20 06:20:33 PDT 2012
Anssi,
OK, may I overreact a bit. It's just that I don't like GPL much,
specially when it used on codes that rely on non GPLed codes. But this
thing of licensing issue is delicate (and boring), so you'll excuse me
if I don't give you one opinion on what you should. The most I can say
is that when I got a clearer grasp of GPL, I change the license of my
code to LGPL.
On a second read I see that you also depend on the gsl library, so
perhaps you have to make it GPL. I don't know.
Joaquim
> Dear Joaquim,
> thanks for pointing that out.
> There´s absolutely no intention to abuse any of the great work of the
> gdal/ogr developers. Rather the opposite.
> The license is being discussed as we speak and we're considering
> various options. What would you suggest? Should it be MIT or would ,
> for example, Modified BSD License do?
> Best,
> Anssi
> On Wed, Jun 20, 2012 at 2:49 PM, Joaquim Luis<jluis at ualg.pt>  wrote:
>> One other thing called my attention. If, as we can read on the wiki page of
>> OFGT
>> "... Most of the stand-alone programs use GDAL libraries and many of the
>> scripts rely heavily on GDAL command-line utilities."
>> than why the OFGT's licence is GPL?
>> I know MIT's license allows it, but it clearly looks an abuse to me.
>> Joaquim
>>> Distributing software via dropbox is a rather unusual practice, you
>>> might consider hosting it elsewhere...
>>> Etienne
>>> On Wed, Jun 20, 2012 at 6:53 AM, chenliang wang<hi181904665 at msn.com>
>>>   wrote:
>>>> Hi, Anssi
>>>> Cool ! Open Foris Geospatial Toolkit is a great geospatial library .
>>>> Unfortunately, I can't download it from dropbox site because ofInternet
>>>> censorship  of China. Can u upload it to other site or send it for me?
>>>> Thanks a lot. I are a Linux and MINGW user .
>>>> Chen-Liang Wang
>>>> 于 2012-6-20 17:26, anssi 写道:
>>>>> If you first rasterize your shapefile to the extent of your raster,
>>>>> you can compute some basic stats and/or full histogram for your
>>>>> polygons using Open Foris Geospatial Toolkit :
>>>>> http://km.fao.org/OFwiki/index.php/Open_Foris_Toolkit
>>>>> Installation instructions are under the "How to get it?" link.
>>>>> Hope you're a Linux user :)
>>>>> Best,
>>>>> Anssi
>>>>> On Wed, Jun 20, 2012 at 6:59 AM, Petteri Packalen
>>>>> <packalen at cs.joensuu.fi>    wrote:
>>>>>> Derek,
>>>>>> Look at the http://starspan.projects.atlas.ca.gov project.
>>>>>> Petteri
>>>>>> On Tue, 19 Jun 2012, jdmorgan wrote:
>>>>>>> Hello,
>>>>>>> Is there a way to do something along the lines of zonal statistics
>>>>>>> with
>>>>>>> gdal.Basically, I have a county shape file and a classified raster
>>>>>>> dataset.I
>>>>>>> would like to count the number of raster pixels/county (FIPS).Is this
>>>>>>> possible with GDAL/OGR?If so can someone point me in the right
>>>>>>> direction?
>>>>>>>   If so, awesome as I plan to do some automation with python.
>>>>>>> Thanks,
>>>>>>> Derek
>>>>>> _______________________________________________
>>>>>> gdal-dev mailing list
>>>>>> gdal-dev at lists.osgeo.org
>>>>>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
