[gdal-dev] gdaltransform with gcps from file
Jan Hartmann j.l.h.hartmann at uva.nl
Sat Jun 23 05:23:02 PDT 2012
Silly question, perhaps. I use gdaltransform with gcps given at the
command line. According to the documentation, gcps can also be put into
the <srcfile> parameter to the program. What is the format of that file?
Most of the time I get an error message like "file fomat not supported".
With four numbers per line the message is "Ungridded dataset". What am I
doing wrong?
Jan
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120623/0a28b604/attachment.html>
