[gdal-dev] Cannot read NetCDF subdatasets
Etienne Tourigny etourigny.dev at gmail.com
Mon Jun 25 09:44:53 PDT 2012
There is no need for a workaround - Paolo simply did not configure
gdal properly. Netcdf support in windows builds is a little different
but is quite simple - just a few lines to edit in nmake.opt
On Mon, Jun 25, 2012 at 12:45 PM, Jeff McKenna
<jmckenna at gatewaygeomatics.com> wrote:
> On 12-06-25 12:25 PM, Paolo Corti wrote:
>> On Mon, Jun 25, 2012 at 4:41 PM, Etienne Tourigny
>> <etourigny.dev at gmail.com> wrote:
>>> For informatioon: the problem was that Paolo was using custom netcdf
>>> libraries and did not add the proper option to configure
>>> --with-netcdf=/usr/local
>> Thanks again to Etienne for helping with this.
>> After closing the filed ticket [1] he has updated the wiki page [2] as
>> well with this, so most likely no one can be in my same shoes
>> p
>> [1] http://trac.osgeo.org/gdal/ticket/4717#comment:7
>> [2] http://trac.osgeo.org/gdal/wiki/NetCDF
> Thanks for updating the wiki.  Unfortunately there is no mention of a
> workaround for Windows; I'm curious if one exists.
> -jeff
> Jeff McKenna
> MapServer Consulting and Training Services
> http://www.gatewaygeomatics.com/
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
