[gdal-dev] Veto wx ComboBox selection before selection change
Gabriel Fusca gabrielfusca at suremptec.com.ar
Mon Jun 25 10:38:34 PDT 2012
I´m using Windows OS and wx 2.8.12. I tried to use a wxCombobox which has
the capability to veto the change of the selected item from the combobox if
the current selection has changes to save.
I´m trying to use the wxEVT_COMMAND_COMBOBOX_
SELECTED. I want to save the previous selection index and when the user
changes the selection, I want to verify that the previous selection item
has changes to save. If this happens I want to set the combox selection to
the previous index values and notify the user.
Am I doing it wrong? Or it ther another way to do this?
It´s impossible to change the version of Wx.
Regards,
Gabriel Fusca
SUR Emprendimientos Tecnológicos
Perú 345  Piso 5to Oficina "B" (C1067AAG)
Ciudad de Buenos Aires, Argentina
Tel. +54 (11) 4342-2976/84
http://www.suremptec.com/
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120625/01dd2f97/attachment.html>
