[gdal-dev] Errors with ogr2ogr and DXF files (ASCII and BIN)
Even Rouault even.rouault at mines-paris.org
Wed Jun 27 07:10:04 PDT 2012
Selon Mac Wind <macwind2 at gmail.com>:
> Hi.
> Using OGR, I'm trying to reproject a DXF file. I'm using ogr2ogr, but
> I get two type of errors depending if I start with a BIN DXF or an
> ASCII DXF file.
> With BIN DXF:
> ogr2ogr -s_srs 27492.prj -t_srs 4326.prj myfile_WGS84.dxf myfile_BIN12.dxf
> I get this error message:
> FAILURE:
> Unable to open datasource `myfile_BIN12.dxf' with the following drivers.
> [+ the list of installed drivers, included DXF]
Binary DXF is not supported.
> With ASCII DXF
> ogr2ogr -s_srs 27492.prj -t_srs 4326.prj myfile_WGS84.dxf myfile_ASCII12.dxf
> FAILED: Layer entities already exists, and -append not specified.
>         Consider using -append, or -overwrite.
> ERROR 1: Terminating translation prematurely after failed
> translation of layer entities (use -skipfailures to skip errors)
> (effectively, 'entities' does exist, but this the expected situation, right?)
You must explicitely specify the output driver with -f DXF (otherwise
And you must delete myfile_WGS84.dxf if it exists before.
