[gdal-dev] Possibility to add a MorphFromESRI-like feature to gdalwarp ?
Matthieu Rigal rigal at rapideye.net
Fri Jun 29 07:03:58 PDT 2012
Brilliant ! I am sorry, I had never seen that possibility. But it works
perfectly.
Thanks again Etienne,
Matthieu
On Fri, Jun 29, 2012 at 3:30 PM, Etienne Tourigny
<etourigny.dev at gmail.com>wrote:
> As referenced in SetFromUserInput [1] you can force a morphFromESRI by
> prefixing a WKT definition (file or WKT string) with "ESRI::"
> I'm pretty sure that gdalwarp uses SetFromUserInput to get the SRS
> definition.
> [1]
> http://www.gdal.org/ogr/classOGRSpatialReference.html#aec3c6a49533fe457ddc763d699ff8796
> On Fri, Jun 29, 2012 at 7:09 AM, Matthieu Rigal <rigal at rapideye.net>
> wrote:
> > Hi guys,
> > When asking gdalwarp to warp from a WKT projection generated by ESRI, it
> > will fail when attempting to convert it to Proj4 (ex:
> Lambert_Conform_Conic
> > projections).
> > Wouldn't it be possible to integrate some check/transformation like the
> one
> > done in Python here :
> > http://nullege.com/codes/search/osgeo.osr.SpatialReference.MorphFromESRI
> > Sorry, I am not a C++ dev and I won't be able to contribute...
> > Regards,
> > Matthieu
RapidEye AG
Molkenmarkt 30
14776 Brandenburg an der Havel
Germany
Follow us on Twitter! www.twitter.com/rapideye_global
Head Office/Sitz der Gesellschaft: Brandenburg an der Havel
Management Board/Vorstand: Ryan Johnson
Chairman of Supervisory Board/Vorsitzender des Aufsichtsrates: Robert
Johnson
Commercial Register/Handelsregister Potsdam HRB 24742 P
Tax Number/Steuernummer: 048/100/00320
VAT-Ident-Number/Ust.-ID: DE 815303842
DIN EN ISO 9001 certified
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120629/24ef073c/attachment-0001.html>
