[gdal-dev] Trouble with georeferenced PDF
Rahkonen Jukka Jukka.Rahkonen at mmmtike.fi
Thu Mar 1 04:34:32 EST 2012
I had a quick test by converting one GeoTIFF into georeferenced PDF files with different parameters and opening results with Acrobat Reader and TerraGo toolbar.
For TerraGo the metadata must be in OGC_BP style and ISO style metadata must not exist (option BOTH does not work). What is odd is that TerraGo toolbar finds coordinates if I run gdal_translate with -a_srs
epsg:3067 but not if I run it with -a_srs epsg:32635.
There seems to something different in the PDF headers, here are short captures
from the beginnings of the files
EPSG:32635 which is not understood by TerraGo toolbar
%PDF-1.6
%<bh:ff><bh:ff><bh:ff><bh:ff>
7 0 obj
\<\< /CTM [ (0.5487347256) 0 0 (0.5487347256) (3409989.640548643)
(6956053.279989699) ] /Description (WGS 84 / UTM zone 35N) /Neatline
EPSG:3067 which is OK for TerraGo
%PDF-1.6
7 0 obj
\<FEFF0045005400520053003800390020002F00200054004D0033003500460049004E00280045002C004E0029>
/Neatline
Images are available here
http://latuviitta.org/documents/GDAL_OGC_32635.pdf
http://latuviitta.org/documents/GDAL_OGC_3067.pdf
-Jukka Rahkonen-
-Jukka Rahkonen-
