[gdal-dev] Re: Trouble with georeferenced PDF
Jukka Rahkonen jukka.rahkonen at mmmtike.fi
Thu Mar 1 15:49:40 EST 2012
Even Rouault <even.rouault <at> mines-paris.org> writes:
> Hum, you can perhaps try something. In the projection information, I've added
> a WKT attribute that is not in the OGC BP spec and is an extension only used
> for the benefit of GDAL when it is found (it avoids loosing information when
> going from/to OGC BP representation). You can disable its writting by setting
> the GDAL_PDF_OGC_BP_WRITE_WKT configuration option to NO. But I'm a bit
> skeptical it will help. In my testing, the toolbar just happily ignored it, as
> it should.
No difference by using  --config GDAL_PDF_OGC_BP_WRITE_WKT NO
-Jukka-
