[gdal-dev] Oracle Locator Support
Nicolas Simon nicolas.simon at spw.wallonie.be
Fri Mar 2 04:46:27 EST 2012
Bill,
	It's Ok with Locator-only installation.
Nicolas Simon
> -----Message d'origine-----
> De : gdal-dev-bounces at lists.osgeo.org
> [mailto:gdal-dev-bounces at lists.osgeo.org]De la part de Bill Teluk
> Envoyé : vendredi 2 mars 2012 4:28
> À : gdal-dev at lists.osgeo.org
> Objet : [gdal-dev] Oracle Locator Support
> Hi,
> I'm investigating migrating an application to using Oracle
> Locator as it's
> Spatial Database.  The application uses the ogr2ogr utility
> for a number of
> functions on our existing platform, such as data loading into
> the database.
> We may also use some OGR API calls in the future.
> Is GDAL/OGR designed to work with Locator-only installations,
> or does it
> need the full Spatial installation.
> Thanks,
> Bill Teluk.
> http://osgeo-org.1560.n6.nabble.com/Oracle-Locator-Support-tp4
538403p4538403.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
gdal-dev mailing list
http://lists.osgeo.org/mailman/listinfo/gdal-dev
