[gdal-dev] drawing line using OGR and mysql in mapserver
Chaitanya kumar CH chaitanya.ch at gmail.com
Fri Mar 2 10:49:29 EST 2012
Modify the table to store the line as a wkt geometry in string format.
On Fri, Mar 2, 2012 at 9:12 PM, Murat Beyhan <beyhan at deprem.gov.tr> wrote:
> Chaitanya,
> I mean What should I do,
> Still could not draw a simple line on the map,
> Please how can I overcome this issue. How can I change VRT file.
> in order to read data from such table storing data as linestring
> regards
> murat
> On Fri, 2012-03-02 at 21:08 +0530, Chaitanya kumar CH wrote:
> > I was talking about the geometry format of the line. You have to
> > decide for yourselves about the efficiency.
> > On Fri, Mar 2, 2012 at 8:57 PM, Murat Beyhan <beyhan at deprem.gov.tr>
> > wrote:
> >         Chaitanya,
> >         What do you prefer and which way more fast to draw line and
> >         point
> >         because I also draw point about 160000 and I use wkbpoint.
> >         Any way how to change and What I will change in the vrt.
> >         could you tell something about it
> >         thanks
> >         On Fri, 2012-03-02 at 20:23 +0530, Chaitanya kumar CH wrote:
> >         > Murat,
> >         > You specified the encoding for GeometryField in the VRT as
> >         WKT. OGR
> >         > expects a WKT if you do that. Either change the data or the
> >         VRT.
> >         > On Fri, Mar 2, 2012 at 6:42 PM, Murat Beyhan
> >         > wrote:
> >         >         I have to say this is not view
> >         >         this is a table created.
> >         >         Because I could not declare type of geom field as a
> >         string
> >         >         than I create
> >         >         geometry field column in spatial mysql database..
> >         >         On Fri, 2012-03-02 at 18:39 +0530, Chaitanya kumar
> >         CH wrote:
> >         >         > Murat,
> >         >         > Can you show a sample output of your view?
> >         >         > SELECT * FROM geom;
> >         >         > On Fri, Mar 2, 2012 at 6:12 PM, Murat Beyhan
> >         >         > wrote:
> >         >         >         Dear Chaitanya,
> >         >         >         I see what you explain first I convert lat
> >         lon data
> >         >         to string
> >         >         >         then I
> >         >         >         concatenate them to string again. But I
> >         would like
> >         >         to ask
> >         >         >         I have already add data to mysql table as
> >         follows is
> >         >         this also
> >         >         >         correct
> >         >         >         because when I browse table it seems it
> >         store data
> >         >         in geometry
> >         >         >         field
> >         >         >         but mapserver gives error
> >         >         >         Unable to identify source field 'fault'
> >         for
> >         >         geometry.
> >         >         >         any way
> >         >         >         I will try to convert data first then I
> >         can return
> >         >         back you.
> >         >         >         Regards...
> >         >         >         ps.
> >         >         >         ogrinfo
> MYSQL:dynamic,user=root,password=mysql_123,host=localhost,port=3306,tables=geom
> >         >         >         INFO: Open of
> `MYSQL:dynamic,user=root,password=mysql_123,host=localhost,port=3306,tables=geom'
> >         >         >              using driver `MySQL' successful.
> >         >         >         1: geom (None)
> >         >         >         it say none in geom
> >         >         >         may be first I have to do what you say
> >         >         >         thanks
> >         >         >         Murat
> >         >         > Best regards,
> >         >         > Chaitanya kumar CH.
> >         >         > +91-9494447584
> >         >         > 17.2416N 80.1426E
> >         >         > This message has been scanned for viruses and
> >         >         > dangerous content by MailScanner, and is
> >         >         > believed to be clean.
> >         >         Murat BEYHAN
> >         >         Jeofizik Y.Müh.
> >         >         T.C. Başbakanlık
> >         >         Afet ve Acil Durum Yönetimi Başkanlığı
> >         >         Deprem Dairesi Başkanlığı
> >         >         Eskişehir Yolu 12. Km.
> >         >         Lodumlu/ANKARA
> >         >         Tel: 312 2872680-1556
> >         >         email:beyhan at deprem.gov.tr
> >         > Best regards,
> >         > Chaitanya kumar CH.
> >         > +91-9494447584
> >         > 17.2416N 80.1426E
> >         Murat BEYHAN
> >         Jeofizik Y.Müh.
> >         T.C. Başbakanlık
> >         Lodumlu/ANKARA
> > Best regards,
> > Chaitanya kumar CH.
> > +91-9494447584
> > 17.2416N 80.1426E
> Murat BEYHAN
> Geophysical Engineer, M.Sc.
> Prime Ministry
> Disaster and Emergency Management Presidency
> Earthquake Department
> Address: Eskisehir Yolu 12. Km.
> Lodumlu/ANKARA
Best regards,
Chaitanya kumar CH.
+91-9494447584
17.2416N 80.1426E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120302/5493e5ec/attachment-0001.html
