[gdal-dev] libkml GroundOverlay support
Clarke, Trevor tclarke at ball.com
Mon Mar 5 10:01:22 EST 2012
I am in need of support for GroundOverlay loading from KML and I've been
prototyping some ideas. The biggest issue is that GroundOverlays are
conceptually raster data in a primarily vector format so it's unclear
how OGR/GDAL should handle this. It's useful to have relational
information and bounding rectangle information coming back from OGR but
OGR shouldn't load the raster data, that's obviously a GDAL job.
For background, here's now GroundOverlays are specified. A GroundOverlay
element has to have a LatLonBox to specify the bounding rectangle for
the imagery and it also needs to have a URL specifying the source of the
imagery. This can be a web url, a file url or a relative path (if it's
in a KMZ). In addition, descriptive metadata and a DrawOrder can be
specified. Defined behavior when an image URL isn't specified or can't
be loaded is to draw a rectangle with the specified (or default) color
and style information.
I propose the following behavior. In OGR, the GroundOverlay is added as
a polygon feature specifying the bounding box and style/draw information
for the "can't load" display mode. Draw order, and URL are attached as
fields as well as a field indicating this is a GroundOverlay and not a
Placemark. This is enough to load and work with the bounds, etc. and the
URL can be passed to GDAL for raster loading (via /vsicurl/ if
necessary).
This will not allow a user to pass a KML directly to GDAL and get access
to the embedded images.
Thoughts?
Trevor R.H. Clarke
Ball Aerospace & Technologies Corp
Opticks, Free Your Imagery (http://opticks.org)
GPG key available on random.sks.keyserver.penguin.de
This message and any enclosures are intended only for the addressee.  Please
notify the sender by email if you are not the intended recipient.  If you are
not the intended recipient, you may not use, copy, disclose, or distribute this
message or its contents or enclosures to any other person and any such actions
may be unlawful.  Ball reserves the right to monitor and review all messages
and enclosures sent to or from this email address.
